CFAL12864C with PIC32 Blank Screen/Shutdown issue
Well121
Greeting,
I am using CFAL12864C with PIC32, I have some problem with the code.
Here is my issue.
1. I am using code based on the datasheet and example code on the website but I have to change some of the code to fit with my microcontroller.
2. I follow the power up/down timing on the datasheet.
3. I am able to initialize the first screen (by using bmp() funtion from the datasheet). At this moment if I do nothing the LCD show the first screen as long as I supplied power.
4. If I write the screen by using bmp() again, sometime it work but sometime the screen blank and nothing display again.
5. This issue happen frequently and I think that I have problem with my code or something.
6. Schematic and power source I have follow your example in the datasheet.
Any advice will be very appreciated. Thank you in advance.
Character LCD Modules
