CFAH2004K initialization String?
BlogSpider
I'm having issues. What's the initialization string for this LCD? I want to enable ALL FOUR LINES.
It should be the standard sequence for any 20x4 LCD. Here is one example:
void Write_LCD_Data_8(ubyte data)
  //Make register select 1, Make R/W 0=write
  OnRsH();
  OnRwL();
  //Write the data to the port.
  data_register=data;
  Update_Buttons_From_Data_Register();
  //Strobe enable
  Sleep(1);
  OnEH();
  Sleep(1);
  OnEL();
void Write_LCD_Control_8(ubyte data)
  //Make register select 0, Make R/W 0=write
  OnRsL();
  OnRwL();
  data_register=data;
  //Strobe enable
  Sleep(1);
  OnEH();
  Sleep(1);
  OnEL();
void Init_LCD_8(void)
  //data sheet.
  Sleep(40);
  Write_LCD_Control_8(0x38);
  Sleep(5);
  Sleep(125);
  //038h is Function set:
  //8 bit,
  //2 line
  //F = (5x8)
  Sleep(1);
  //"Display off"
  Sleep(2);
  Write_LCD_Control_8(0x08);
  //"Display clear"
  Sleep(2);
  Write_LCD_Control_8(0x01);
	Sleep(2);
  Write_LCD_Control_8(0x06);
	Sleep(2);
  Write_LCD_Control_8(0x0F);
	Sleep(2);
The addresses to access the lines are:
line  value written to control register
  0   0x80
  2   0xC0
  3   0x94
  4   0xD4
Then you write the data to be shown to the data register.
Please let me know if that is what you needed, or if you have other questions.
(ref: http://www.crystalfontz.com/software/CFAH_WinTest/index.html )
