My company bought a sample CFAH2002A-TMI-JT for testing.     I'm working to get it working for our application.
We use a 14 pin header connector on pins 1 to 14. We don't use pins 15 and 16 (backlight). To light the backlight i added a jumper on J1 and a 50 Ohms resistor on J2. 31mA of current in the leds, nice glow, below the backlight specs, works good.
Next, our controler PCB is sending a fixed voltage for contrast. This voltage is around 0.46V and not resulting in a nice contrast on the CFAH2002A-TMI-JT. I would like to add two resistor on the display PCB directly to set the contrast. Is it possible ? Where should i put the resistors ?
I would like to know if it is possible to have the displays customized for future quantity orders. Resistors for backlight and contrast already added by Crystalfontz. And connector, could you add it for us ?
We use a 3M D2514-6002-AR or 3M 30314-6002HB. Our minimum order quantity will be 100.
