Cfah2002a-rmc-jp Setup?
proverb
i just bought it today so it will be coming in later this week i hope..
i was just hoping i could get all my materials needed and research before it gets in..
so far i got a solder heh
what elese do i need resistors? if so what kind
also if there is a guide out there ment for the CFAH2002A-RMC-JP please hook me up with it.. Thanks
proverb
proverb
i just bought the lcd thats it should i have bought anything elese or could i find the other stuff around my area?
We do not recommend the parallel modules (such as the one you are interested in) for end-user PC applications. These modules require more extensive wiring knowledge and the proper tools. These modules are primarily intended for OEM (manufacturer) use, and as such, we do not carry any cables, brackets, or serial adapters for these modules.
We do not offer end-user tech support on the CFAH*, CFAG* or CFAP* series modules in PC applications. We will not accept returns on CFAH*, CFAG* or CFAP* modules damaged in an attempt to connect them to a PC.
The serial modules and kits (634, 633, 632 models and kits: http://www.crystalfontz.com/products/select_kit.html) are best suited for PC applications.
Please see this forum thread for our PCuser LCD recommendations:
https://forum.crystalfontz.com/showthread.php?s=&postid=1922
However, good wiring guides for HD44780 compatible LCD's can be found:
http://www.myrolypoly.com/lcd_project/lcd_project.html
http://www.icehw.net/article.asp?id=104
http://www.geocities.com/ResearchTriangle/1495/ee_lcd.html
http://www.overclockers.com.au/techstuff/a_diy_lcd/
http://www.hardforum.com/showthread.php?threadid=248302
You can also go to http://forums.bit-tech.net/showthread.php?threadid=5582 and search for "assuming alphanumeric" and you will find a short Q/A post on parallel displays.
Your mileage may vary.
