CFAH1602A-RGB-JP backlight questions
floodo1
what size limiting resistor should i use for the backlight. im a newb to this.....what size resistor for the backlight and for the contrast adjustment.
i have a CFAH1602A-RGB-JP
thanks in advance
l8tz
josh
Character LCD Modules
In short:
Rlimit = (+5v - 4.2v)/(130mA maximum) = 6.15 ohms minimum
Add a 5W wirewound 100 ohm in series if you want to dim it.
Use a 10K linear taper pot for the contrast.
Please see this thread for a detailed explanation.
