Cfag320240c-fmi-t
Snif
witch software to use for this Graphic LCD ?
Can sommeone tell me what i just must order for getting the lcd to work on e pc ? ?
Inverter + CFAG320240C-FMI-T and ?
Or is there e lcd display that works fine on e pc with this size 320*240 ?
We do not offer end-user tech support on the CFAH*, CFAG* or CFAP* series modules in PC applications. We will not accept returns on CFAH*, CFAG* or CFAP* modules damaged in an attempt to connect them to a PC.
The serial/USB modules and kits (634, 633, 632 models and kits: http://www.crystalfontz.com/products/select_kit.html) are best suited for PC applications.
Please see this forum thread for our PCuser LCD recommendations:
https://forum.crystalfontz.com/showthread.php?s=&postid=1922
