Ok, I've finally gotten the display work ... as in display text or graphics... using a PIC microcontroller in 6800 mode.
Now the problem I'm running into is that when the screen is in the middle of drawing, all the pixels that have already been lit become very faint. When it has finished drawing everything and the screen is static, the pixels come back to a normal contrast.
I've been using the sample code settings for the screen initialization. I'm not sure if it's a characteristic of this display or if there's something wrong with the circuit I'm using to power the display. I have a capacitor between 5v and ground for powering the logic circuits and I'm using an external pot between the onboard negative voltage generator and Vo (and ground) for setting the contrast of the screen (for some reason, the pot on the back of the LCD doesn't do the job). Is there anything else I should be worried about?
I have CS set to low permanently because it was my understanding that CS is only for disabling any input to the LCD if you have activity through the parallel interface (for other than controlling the LCD). Since I have the LCD wired directly to pins on the PIC microcontroller, I didn't need to worry about this.
Other than that, everything is the same as the sample code I was provided by the mod of this board (aside from tweaking the code to work in 6800 mode rather than 8080). What could be wrong? I'd really like all the pixels to have high contrast at all times because I plan to be updating the screen data constantly. Thanks for any help you can provide!
-Lee
Here's a sample pic... for those who cared to read this post
(and this is normal, since the screen is not drawing anything at the moment... sorry about the crappy resolution, it's a camera phone)
-Lee
