I am trying to connect the CFAG240128L graphic LCD to a Atmel AVR uC.
This LCD uses a Toshiba 6963 controller.
1. What does the RV pin do? In the interface description, is says H:Reverse, H:Normal. I am assuming it should say H:Reverse, L:Normal?
2. I am having problems reading the status from the T6963 (I always get 0x00). What I am doing is toggling the CE and RD bits from high to low to high (then reading the DB0-7 pins) while WR, RST, C/D are high, does this sound correct to you? To read the status, do I need to send a command on the DB0-7 bits? The LCD appears to be on, I am able to adjust the contrast with a potentiometer.
3. In terms of the general working of the LCD, this is how I understand it. There are basically 8 pixel by 8 pixel blocks of data that may represent a character from internal CGROM for instance. Knowing this there are (30) 8 pixel by 8 pixel blocks of data horizontally. There are also (16) 8 pixel by 8 pixel blocks of data vertically. The way you address the LCD is via an x and y pointer which will point to a specific 8 pixel by 8 pixel block. Is this thinking correct?
4. The LCD comes with a 8kB external memory. The datasheet recommends the user setup the external memory a certain way. In particular, a 3072B text area, a 3072B graphics area, and a 2048B CGRAM area. The 2048B CGRAM area in this case is user programmable correct? In addition to this CGRAM area, there is another on-chip CGRAM on the 6963 right? This 8k external memory can be setup any way the user wants right?
