CFAG16060B init help
vado
CFAG16060B strobing output help
I have created a test circuit and program for the CFAG160160B.
I am interfacing it with a Phillips P89LPC922 (based on a 8051 core) microcontroller. I am mainly following the initialization code found in a recent post.
However, I am only seeing a strobing line on the display.
One problem that I want to rule out is the max timing characters (referring to the datasheet).
I believe that at 12MHz, my P89LPC922 is not fast enough to perform a read instruction; however it appears to me that during a WRITE only minimum times must be met, and the maximum time is not important.
Does anyone have any information regarding the correction of a strobing screen?
Thank You
