I am using CFAG14432D and trying to display simultaneously the graphic image (on the left part of the screen) and text from CGROM (on the right part of the screen). Please correct me if I am wrong, but it seems like ST7920 controller only supports text from CGROM/HCGROM mapped to DDRAM or Graphic RAM(GDRAM).
Do I need use initialization with extended commands to use Graphic RAM?
So far I can display ether text or graphic sequentially (but not at the same time).
Another question: how do I switch from graphic to text and back. Currently it works for me only if I issue initialization:
For text mode:
Reinitialization for graphic:
What is correct way to do it?
Thanks.
For text mode:
void GLCD_Init(void) // Text mode???
GLCD_WriteByte (RS_INSTR, 0x30); // Specify 8 bit interface and basic instruction set.
Wait_mS (1);
GLCD_WriteByte (RS_INSTR, 0x06); // Specify 8 bit interface and basic instruction set.
Wait_mS (1);
GLCD_WriteByte (RS_INSTR, 0x0C); // Specify Display on, Cursor off and Blink off.
Wait_mS (1);
GLCD_WriteByte (RS_INSTR, 0x01); // Display clear. Fill DDRAM with "20H", and set DDRAM address counter to "00H"
Wait_mS (10);
GLCD_WriteByte (RS_INSTR, 0x02); // AC Increase (cursor move right), don't shift the display.
Wait_mS (1);
GLCD_WriteByte (RS_INSTR, 0x80); // Select extended instruction set.
Wait_mS (1);
GLCD_WriteByte (RS_INSTR, 0x30); // Graphic display ON.
Wait_mS (1);
void GLCD_Init_Text(void)
Wait_mS (2);
GLCD_WriteByte (RS_INSTR, 0x06); // Cursor move to right ,DDRAM address counter (AC) plus 1
Wait_mS (2);
GLCD_WriteByte (RS_INSTR, 0x0C); // Display on, cursor on, blink on
Wait_mS (2);
GLCD_WriteByte (RS_INSTR, 0x01); // Fill DDRAM with "20H", and set DDRAM address counter to "00H"
Wait_mS (10);
GLCD_WriteByte (RS_INSTR, 0x02); // Set DDRAM address counter (AC) to "00H", and put cursor to
// origin the content of DDRAM are not changed
Wait_mS (2);
GLCD_WriteByte (RS_INSTR, 0x80); // Set DDRAM address to address counter (AC)
Wait_mS (2);
// Set Extended function set
GLCD_WriteByte (RS_INSTR, 0x30); // Select extended instruction set.
Wait_mS (2);
GLCD_WriteByte (RS_INSTR, 0x32); // Graphic ON
Wait_mS (2);
GLCD_WriteByte (RS_INSTR, 0x36); // Select extended instruction set.
Wait_mS (2);
Thanks.
