CFAG12864BTMIV with liquidmp3 problem
m00k
hi,
i just got a CFAG12864BTMIV glcd, but i got some problems getting it to work with liquidmp3 0.9.4 alpha. It shows some activity on the screen , but its garbage. The lcd was wired for me by lc-designs (CS1 and CS2 swapped), and since I got the lcd working under LCDStudio i think the wiring is ok. However it doesnt run really smooth under LCDstudio (extreme heavy cpu load). I also have problems getting it to work ok under LCDHype. Anyone have any clue what could be wrong or is it a rtfm problem?
thanks
m00k
m00k
pic of the garbage i see whne using liquidmp3
Gigio2k
hi, i've the same display but i don't see nothing
i post some questions :
1) whit the power connected and parallel disconnect i see only the blue backlight and don't see nothing else, it's good or bad ?
2) the voltage is :
(LCD PIN) (V)
1 # 5
3 # 0.9
14 # 5
18 # 0.01~0.02
19 # 2.7
it's correct ?
3) with lpt_tester.exe the tension arrive to lcd correct (d0-d7 Strobe line and init) , i use Winxp
4) i've install the liquind mp3, lcd info and more ,but i see only the backlight ... what's the problem ?
5) MOST INPORTANT in the CFAG12864BTMIV the CS1 is connected to Lpt pin 16 and CS2 to 14 is correct or not ?
Tnk in advance
m00k
hi,
well seems my wiring doesnt go to well with liquidmp3 or the ks0108 tester i downloaded, so i use LCDHype now and that works great.
i have CS1 on 16 and CS2 on 14, but both active high.
m00k
Gigio2k
tnk i try this software.
Last question : what is the Volt on Vo ?
i've a -0,1 but i think is too low to turn on the matrix
and last-last : you have a Reset pin always connect diretly to +5v ?
