M matrixum New member Jun 16, 2005 #1 CFAG12864BTMIV. can this be used effeicently with the atmel atmega8 mcu. ?? Crystalfontz LCD BlogLooking for additional LCD resources? Check out our LCD blog for the latest developments in LCD technology.
C CF Tech Administrator Jun 16, 2005 #2 Ya. Should be fine. How much RAM and flash does that part have? You might want to use a library: http://www.ramtex.dk http://www.easygui.com They include source and should make your job much easier.
M matrixum New member Jun 17, 2005 #3 Well the atmega 8 is a 8 bit microprocessor. It has 512 bytes eeprom, 8k of in system self programmable flash,and 1k internal sram. Last edited: Jun 17, 2005
C CF Tech Administrator Jun 17, 2005 #4 That would be pretty tight for working with a graphic display. You might want to look at a bigger micro (maybe the ATMEGA series) or look at using a text display.
