I have recently purchased a CFAG12864B-TMI-V display with LED backlighting. I have not received the display yet but am currently working on a PCB and the circuitry for the display. I am a little confused about the backlighting schematics in the documentation. Option 1 seems straightforward - wiring directly to the A and K pads on the side of the display through a resistor. My question has to do with Option 2. Do I just need to run my +5 volts to an 8 ohm resistor and then to pin 19? Are pin 19 and the A pad internally collected on the LCD? If they are, then I assume pin 20 and pad K are also connected.
Bob Gardner
Bob Gardner
