CFAG128128A Connexion issue
JJC
I am working on a project to create a graphic function controller with a PIC 18F and a CFAG128128A display.
The problem is that I can't figure out how to connect it to the power supply.
Apparently there is a supply for the logic (5 V) and a supply for the LCD, for the backlight I suppose.
However, the datasheet is extremly unclear concerning the supply voltage for the LCD.
What is Vo? What do I connect to pin no 4?
And what on earth is the -16v output for pin no 20???
If anybody could answer me very quickly, I'd be extremely grateful!
JJC:
Here is a quick sketch of what the connection should look like:
attachment.php
Please note that the pin table in the mechanical drawing is wrong. The pin table in the text is right. The datasheet should be fixed in a bit.
Here is a post that explains how to connect the backlight:
https://forum.crystalfontz.com/showthread.php?p=192#post192
snoopy-km
Sure, Vo(V0) is for contrast adjustment (it could be very sensitive)
pin 21 - backlight (+5V)
pin 22 - backlight (GND)
* PLEASE LOOK AT THE POST BELOW -ADMIN
The datasheets have been updated / corrected to reflect the pin functions in the mechanical drawing.
You can find the updated datasheets here.
Do Not Connect +5v Directly To The Backlight !!
This is a dangerous way to put it. This description would be better:
Pin 21 = LED A (anode / positive)
Pin 22 = LED K (cathode / negative)
Connecting +5v and ground will damage the backlight. You need a current limiting resistor as follows:
CFAG128128A-STI-TZ ==> Rlimit = (5v-3.5v)/0.096A = 16 ohm minimum
CFAG128128A-TMI-TZ ==> Rlimit = (5v-3.5v)/0.120A = 13 ohm minimum
CFAG128128A-YYH-TZ ==> Rlimit = (5v-4.2v)/0.500A = 1.6 ohm minimum
. . . Here is a post that explains how to connect the backlight:
JJC
Thank you!
Thank you very much for replying so quickly, you've been extremely helpful!
JJC
