chris.long
I have based all of my code on this post:
CFA635 with PIC host #18
I am using MPLAB v.8.91 with the Microchip C18 compiler on a Windows 7 64-bit Pro machine.
I am powering the LCD through H1 +5Vdc & Ground and have pins 1 and 2 connected to the PIC18F4520 Tx (pin 25) and Rx (pin 26) according to the pin-out on page 32 of the CFA735-TML-KR1 datasheet.
I am able to send commands with the 635_WinTest software but have not connected both the external power supply and USB at the same time. I have not cleared J10 on the CFA735-TML-KR1.
When I send the "Hello World" packet listed in the aforementioned thread, the CFA735-TML-KR1 does not display text nor does it respond. I have verified that I am getting the correct CrC code (0xE50E). My code is listed below. Thank you for your assistance.
#include <p18f4520.h>
#include <delays.h>
#include <stdio.h>
#include <stdlib.h>
#include <usart.h>
#include <string.h>
#include <delays.h>
void InitPic(void);
unsigned short get_crc(unsigned char count,unsigned char *ptr);
void send_CRC(void);
// Configuration bits
#pragma config OSC = HS //High-speed Oscillator
#pragma config FCMEN = OFF //Fail-Safe Clock monitor disabled
#pragma config IESO = OFF //Int-Ext. Switch-Over disabled
#pragma config PWRT = OFF //Power-up Timer disabled
#pragma config BOREN = OFF //Brown Out Detect disabled
#pragma config WDT = OFF //Watchdog Timer disabled
#pragma config MCLRE = ON //Master Clear Enabled
#pragma config STVREN = ON //Stack full/underflow will cause reset
#pragma config LVP = OFF //Single-Supply ICSP disabled
#pragma config XINST = OFF //Extended CPU mode disabled
#pragma config DEBUG = ON //Debugger Enabled
#pragma config CP0 = OFF, CP1 = OFF, CP2 = OFF, CP3 = OFF
#pragma config CPB = OFF, CPD = OFF
#pragma config WRT0 = OFF, WRT1 = OFF, WRT2 = OFF, WRT3 = OFF
#pragma config WRTB = OFF, WRTC = OFF, WRTD = OFF
#pragma config EBTR0 = OFF, EBTR1 = OFF, EBTR2 = OFF, EBTR3 = OFF
#pragma config EBTRB = OFF
//GLOBAL VARIABLES
unsigned int crc_temp;
unsigned int crc;
unsigned long int Combine_CrC;
unsigned char array_size;
unsigned char CrC_Msb,CrC_Lsb;
unsigned char i;
//CHARACTER ARRAYS
unsigned char data_HW[24] = {0x1F,0x16,0x00,0x00,'H','e','l','l','o',' ','W','o','r','l','d',' ',' ',' ',' ',' ',' ',' ',' ',' '};
//FUNCTIONS
void InitPIC(void)
//PORTS
TRISA = 0x00; // Configure PORT A as output
//USART
TRISCbits.TRISC6 = 0; //TX1 PIN 31
TRISCbits.TRISC7 = 1; //RX1 PIN 32
OpenUSART( USART_TX_INT_OFF &
USART_RX_INT_OFF &
USART_ASYNCH_MODE &
USART_EIGHT_BIT &
USART_CONT_RX &
USART_BRGH_HIGH, 10 ); //130 is used for 20MHz Fosc and 9600 baud
//10 is used for 20MHz Fosc and 115200 baud
//printf((const far rom char *)"\n\rInitPIC\n\r");
unsigned short crc; //Calculated CRC
unsigned char i; //Loop count, bits in byte
unsigned char data; //Current byte being shifted
crc = 0xFFFF; // Preset to all 1's, prevent loss of leading zeros
while(count--)
data = *ptr++;
i = 8;
do{
if((crc ^ data) & 0x01)
crc >>= 1;
crc ^= 0x8408;
else crc >>= 1;
data >>= 1;
} while(--i != 0);
return (~crc);
void send_CRC(void)
CrC_Lsb = crc;
CrC_Msb = crc/256;
putcUSART(CrC_Lsb); //LSB CRC, 14 or 0x0E
putcUSART(CrC_Msb); //MSB CRC, 229 or 0xE5
void main(void) {
char c[10];
InitPIC(); //sets up i/o etc
array_size = 24;
while(1)
Delay10KTCYx(255);
while (BusyUSART()); //checks to make sure the USART bus is not busy
crc = get_crc(array_size,data_HW);
for (i = 0; i < 25; i++)
putcUSART(data_HW[i]); // alternative method putcUSART(data);
//putrsUSART((const far rom char *)"\n\rSending Data\n\r"); //These statements are for test purposes and
//Delay1KTCYx(125); //are sent to a terminal on my PC to verify data transmission
send_CRC();
PORTAbits.RA0 = 0; //Test LED on
//Delay10KTCYx(255);
while(DataRdyUSART() !=1); //wait for data to be present on bus
getsUSART(c,4);
PORTAbits.RA0 = 1; //Test LED off
Delay10KTCYx(255);
Delay10KTCYx(255);
PORTAbits.RA0 = 1;
Delay10KTCYx(255);
PORTAbits.RA0 = 0;
Delay10KTCYx(255);
// //putrsUSART((const far rom char *)"\n\rData Sent\n\r"); //These statements are for test purposes and
// //printf((const rom far char *)"\n\r%X",CrC_Lsb); //are sent to a terminal on my PC to verify CrC
// //printf((const rom far char *)"\n\r%X",CrC_Msb);
// //printf((const rom far char *)"\n\r%X",crc);
Delay10KTCYx(255);
