CFA635TMFKS1 is not responding to "example-635" program (Crystalfontz example code for Linux).
Previously a CFA633-YYB-KS was attached to the same serial port (at that time the port was set to 19200 baud) and the Crystalfontz example Linux program "example-633" functioned correctly (and it still does when re-connected to test).
The CFA635 was connected using the WR232Y22 serial cable and the included power cable, the serial port has been configured to 115200 baud. The following command:
example-635 /dev/ttyS0 115200
runs, indicates that the port is opened at the correct baud rate, then ends with the following;
Serial_Init:: success
"/dev/ttyS0" opened at "115200" baud.
Timed out waiting for a response.
Ctrl-C to exit.
Updated display, now waiting for packets
(nothing happens past that). Any suggestions? Thanks in advance four your help!
Ctrl-C to exit.
