CFA634-YMC-KU USB Display
Ferrari355
So to understand this their is no need for any other power Cables... All I need is just to plug the display into the Usb port and it should turn on correct? Also what programs support the use of this display? I would love it to show my system temps on it And Winamp.. Or maybe have it switch displays like every 5 Seconds or so.
Correct, you only need the WRUSBY03 cable with the USB 632 or 634, it will pull the power from there.
CrystalControl supports the display, and you can set up LOTS of screens and have them alternate if you want.
3DXPLODE
HEY
ARE YOU UP AND RUNNIN WITH TEMP DISPLAYS AND STUFF CHECK THIS OUT : )
Ferrari355
umm I have to order the display first.. it's so much for the stuff So i'm going to buy it peice by peice.. first starting with the display since it's like $64 or so.. But I still need a larger case to handle the large mounting bracket. It was much harder to order before because I did not have a Master Card.. But now I got my own :)
3DXPLODE
SORRY
THOUGHT YOU WAS UP AND RUNNIN
THANKS BE TO CF FOR ALLOWING COD SHIPMENT !!!!
I DONT HAVE THOSE NASTY CREDIT CARDS AT ALL .
LEMME KNOW WHEN YOUR SETUP !!
