cfa-634 for Basic stamp
hs1503
Hi
i need som info at seriel to CFA-634 for basicstamp kode
J Larsen
Denmark
Basically, if you can send regular old ASCII text out the serial port, it should show up on the display.
I am pretty sure the basic stamp has some support for serial displays (made by other companies), if you start with that code, you should be pretty close. You may have to change a few of the control codes (cursor position, etc).
