I have just purchaced two 120mm Sunon fans, and they are 6.8w each. And I am goint to use them as variable speed (633 PWM) fans on a radiator in my water cooling setup.
I read on another post that the maximum recomended load of all the fans is 1 amp.
So, 6.8w / 12v = 0.5666amp
And since there is two, 0.5666 * 2 = 1.1333amp
Is this still withing design tolerance for the unit, or should I design a small circut to drive them using the signal from the fan header via a mosfet?
Robert Heffernan
Robert Heffernan
