I recently purchased a 631 with SCAB and am using it to control 5 120mm fans. 2 of the fans came with my Silverstone TJ09 case, the other 3 are Scythe S-Flex SFF21F. 2 of the Scythe fans are on a Y cable connected to 1 SCAB port. The fan RPM divider in CC2 is set at 1, which shows my fans at around 1600 RPM at 100% and tracks with the mfg. data for these fans.
When running with manual power control in CC2 if I take the fans to 0% they don't stop, but slow to about 400 RPM. Is this normal behavior?
Otherwise, using 4 thermal probes and automatic fan power I'm really pleased with the performance. My PC is very quiet, except under heavy load and even then it's still pretty quiet.
