cc2_rss Request
jdgordon,
A request to enhance your rss/sml plugin. I currently read 3 lines to display from weather.com The 3 lines as displayed are as follows:
WeatherClicks - Marion, Iowa Weather
Sun, 06 Mar 2005 09:52:00 CST
Current Weather - 55F Clear
Would it be possible to to add code to truncate the text as received from an rss/xml feed? From the above, I would like to have it display the following:
55F Clear
As you can see, I have removed text from the beginning and end.
Possible?
daks001
jc634 said:
jdgordon,
55F Clear
Possible?
You can do some of that now, with the start and end statements, for example, the current weather and location can be done like;
item00_start="<title>Current"
item00_end=</title>"
item01_start="<title>WeatherClicks -"
item01_end=</title>"
Re: Re: cc2_rss Request
Duh!
I had not used the start/end method, so of course, I did not think of using it!
It does work on both beginning and end. My code as follows:
from="cc2_rss.ini"
sec="feed-#"
opt01="url=http://www.weatherclicks.com/xml/52302"
opt02="interval=60"
opt03="item00_id=@01"
opt04="item00_start=<title>WeatherClicks -"
opt05="item00_end=</title>"
opt06="item01_id=@02"
opt07="item01_start=<pubDate>"
opt08="item01_end= CST</pubDate>"
opt09="item02_id=@03"
opt10="item02_start=<title>Current"
opt11="item02_end=</title>"
I left the date at Sun, 06 Mar 2005 09:52:00 simply because I am not sure if it always be :00.
Thanks for the lesson.;)
So, for the moment, cancel my request. It is not needed!
jdgordon
always happy to help out :D
i do wanna make it a bit more powerful tho coz even with the start/end there is still some sites that is difficult to get what u actually want...
also, yould be happy to hear im working on a gui for it which will let u just highlight the text you want and it will setup the start/end and count automatically :)
________
FERRARI FX SPECIFICATIONS
Sweet!:D
