CC2 isn't displaying on CFA-635
Aymincendiary
I have the CFA-635 running on a machine with SBS 2003. The serial port is on Com1, the device is on COM 4. When I install CC2, for one, it does not have the CFA-635, only 631 thru 634 available to add. I tried using the 634 and CC2 says it finds it however, nothing I add displays on the screen after restart.
I've used CC2 on the CFA-631 on my other machine with success in obtaining CPU, memory, and HDD usage. See if anyone here can point me in the right direction as nothing but the bootup screen appears.
Oh, using one of the free downloads form Crystal Fontz for this particular display works. I have been able to send text to the screen.
Chris
First, are you using the latest version?
https://forum.crystalfontz.com/showthread.php?t=4961
In the add module list there should be the 631,632,633,634,635 and two HD44780's.
It should look like the following:
Aymincendiary
635 is missing, evrything else is there.
No, the CFA-635 option is missing. I will downoad the latest version and run setup again.
Thanks1
Chris
