CC2 feedback
dhs
CrystalControl Admin said:
Thanks for that.
Ill work it into the next CC2 release... probably with an extra directory for other languages.
BUT... i don't think CC1 was localized. I guess it retrieved the commands from the OS.... There should be some kind of api to do so.
To create the localized .ini files seems an hellish work imho.
.puzzled.
I posted in the Sudhian Forum (Shuttle) re the release of CC2 some 4 days ago. In that time 381 people have viewed it and 23 posted a message. Its still on page 1 of the forum too.
I guess the message is, keep going CC Admin/Tech, you`re getting something right and the interest is definately out there. Thanks guys! :D
Steve
EDIT:
Only just ended the first four days and now up to 424 viewers. Thats an extra 43 people since I wrote this earlier today!!!
Thanks Steve... its good to know CC2 is getting a warm reception.
There isnt a localized system for the perfmon counters it seems :(
So i will have to add new screens for languages as they become avaliable.
BlueIce
I have the same problems no cpu usage (always0%) no hd, no bars. I have a 634 with USB.
I have Windows XP PRO DUTCH with SP2.
I already installes the 2 dll's in win sys32 but nothing changed
Is it possible that someone can make cc2_perfmon.ini for win xp dutch ?
CC1 was perfectly running on my sys. For my sys see sig.
Can somebody help me???
This says CC2config :
Fri 24 06:12:52 NOTICE ini_read_byte: value found: m00-s01-r01->options = 5
Fri 24 06:12:52 NOTICE ini_read_dword: value found: m00-s01-r01->scroll_speed = 250
Fri 24 06:12:52 NOTICE ini_check_section: section found: m00-s01-r01-i00
Fri 24 06:12:52 NOTICE ini_read_word: value found: m00-s01-r01-i00->length = 15
Fri 24 06:12:52 NOTICE ini_read_byte: value found: m00-s01-r01-i00->options = 0
Fri 24 06:12:52 NOTICE ini_check_section: section/key not found: m00-s01-r01-i00->id
Fri 24 06:12:52 NOTICE ini_check_key: key found: m00-s01-r01-i00->string
Fri 24 06:12:52 NOTICE ini_read_string: value found: m00-s01-r01-i00->string = "Usage: "
Fri 24 06:12:52 NOTICE ini_check_section: section found: m00-s01-r01-i01
Fri 24 06:12:52 NOTICE ini_read_word: value found: m00-s01-r01-i01->length = 3
Fri 24 06:12:52 NOTICE ini_read_byte: value found: m00-s01-r01-i01->options = 1
Fri 24 06:12:52 NOTICE ini_check_key: key found: m00-s01-r01-i01->id
Fri 24 06:12:52 NOTICE ini_read_dword: value found: m00-s01-r01-i01->id = 2030150316
Fri 24 06:12:52 NOTICE ini_check_section: section found: m00-s01-r01-i02
Fri 24 06:12:52 NOTICE ini_read_word: value found: m00-s01-r01-i02->length = 0
Fri 24 06:12:52 NOTICE ini_read_byte: value found: m00-s01-r01-i02->options = 0
Fri 24 06:12:52 NOTICE ini_check_section: section/key not found: m00-s01-r01-i02->id
Fri 24 06:12:52 NOTICE ini_check_key: key found: m00-s01-r01-i02->string
Fri 24 06:12:52 NOTICE ini_read_string: value found: m00-s01-r01-i02->string = "%"
Fri 24 06:12:52 NOTICE ini_check_section: section not found: m00-s01-r01-i03
Fri 24 06:12:52 NOTICE ini_read_byte: value found: m00-s01-r02->options = 0
Fri 24 06:12:52 NOTICE ini_read_dword: value found: m00-s01-r02->scroll_speed = 250
Fri 24 06:12:52 NOTICE ini_check_section: section found: m00-s01-r02-i00
Fri 24 06:12:52 NOTICE ini_read_word: value found: m00-s01-r02-i00->length = 0
Fri 24 06:12:52 NOTICE ini_read_byte: value found: m00-s01-r02-i00->options = 0
Fri 24 06:12:52 NOTICE ini_check_key: key found: m00-s01-r02-i00->id
Fri 24 06:12:52 NOTICE ini_read_dword: value found: m00-s01-r02-i00->id = 1868801232
Fri 24 06:12:52 NOTICE ini_check_section: section not found: m00-s01-r02-i01
Fri 24 06:12:52 NOTICE ini_read_byte: value found: m00-s01-r03->options = 0
Fri 24 06:12:52 NOTICE ini_read_dword: value found: m00-s01-r03->scroll_speed = 250
Fri 24 06:12:52 NOTICE ini_check_section: section found: m00-s01-r03-i00
Fri 24 06:12:52 NOTICE ini_read_word: value found: m00-s01-r03-i00->length = 0
Fri 24 06:12:52 NOTICE ini_read_byte: value found: m00-s01-r03-i00->options = 0
Fri 24 06:12:52 NOTICE ini_check_key: key found: m00-s01-r03-i00->id
Fri 24 06:12:52 NOTICE ini_read_dword: value found: m00-s01-r03-i00->id = 1868801232
Fri 24 06:12:52 NOTICE ini_check_section: section not found: m00-s01-r03-i01
Fri 24 06:12:52 NOTICE ini_check_section: section found: m00-s02
Fri 24 06:12:52 NOTICE ini_read_string: value found: m00-s02->screen_name = "jc CPU Usage Big Nums"
Fri 24 06:12:52 NOTICE ini_read_byte: value found: m00-s02->options = 0
Fri 24 06:12:52 NOTICE ini_read_word: value found: m00-s02->alt_delay = 5000
Fri 24 06:12:52 NOTICE ini_check_section: section not found: m00-s02-event00
Fri 24 06:12:52 NOTICE ini_read_byte: value found: m00-s02-r00->options = 5
Fri 24 06:12:52 NOTICE ini_read_dword: value found: m00-s02-r00->scroll_speed = 250
Fri 24 06:12:52 NOTICE ini_check_section: section found: m00-s02-r00-i00
Fri 24 06:12:52 NOTICE ini_read_word: value found: m00-s02-r00-i00->length = 11
Fri 24 06:12:52 NOTICE ini_read_byte: value found: m00-s02-r00-i00->options = 0
Fri 24 06:12:52 NOTICE ini_check_section: section/key not found: m00-s02-r00-i00->id
Fri 24 06:12:52 NOTICE ini_check_key: key found: m00-s02-r00-i00->string
Fri 24 06:12:52 NOTICE ini_read_string: value found: m00-s02-r00-i00->string = "CPU "
Fri 24 06:12:52 NOTICE ini_check_section: section found: m00-s02-r00-i01
Fri 24 06:12:52 NOTICE ini_read_word: value found: m00-s02-r00-i01->length = 0
Fri 24 06:12:52 NOTICE ini_read_byte: value found: m00-s02-r00-i01->options = 0
Fri 24 06:12:52 NOTICE ini_check_key: key found: m00-s02-r00-i01->id
Fri 24 06:12:52 NOTICE ini_read_dword: value found: m00-s02-r00-i01->id = 3206762360
Fri 24 06:12:52 NOTICE ini_check_section: section found: m00-s02-r00-i02
Fri 24 06:12:52 NOTICE ini_read_word: value found: m00-s02-r00-i02->length = 1
Fri 24 06:12:52 NOTICE ini_read_byte: value found: m00-s02-r00-i02->options = 0
Fri 24 06:12:52 NOTICE ini_check_section: section/key not found: m00-s02-r00-i02->id
Fri 24 06:12:52 NOTICE ini_check_key: key found: m00-s02-r00-i02->string
Fri 24 06:12:52 NOTICE ini_read_string: value found: m00-s02-r00-i02->string = " "
Fri 24 06:12:52 NOTICE ini_check_section: section found: m00-s02-r00-i03
Fri 24 06:12:52 NOTICE ini_read_word: value found: m00-s02-r00-i03->length = 3
Fri 24 06:12:52 NOTICE ini_read_byte: value found: m00-s02-r00-i03->options = 0
Fri 24 06:12:52 NOTICE ini_check_section: section/key not found: m00-s02-r00-i03->id
Fri 24 06:12:52 NOTICE ini_check_key: key found: m00-s02-r00-i03->string
Fri 24 06:12:52 NOTICE ini_read_string: value found: m00-s02-r00-i03->string = "MHz"
Fri 24 06:12:52 NOTICE ini_check_section: section not found: m00-s02-r00-i04
Fri 24 06:12:52 NOTICE ini_read_byte: value found: m00-s02-r01->options = 0
Fri 24 06:12:52 NOTICE ini_read_dword: value found: m00-s02-r01->scroll_speed = 250
Fri 24 06:12:52 NOTICE ini_check_section: section found: m00-s02-r01-i00
Fri 24 06:12:52 NOTICE ini_read_word: value found: m00-s02-r01-i00->length = 15
Fri 24 06:12:52 NOTICE ini_read_byte: value found: m00-s02-r01-i00->options = 0
Fri 24 06:12:52 NOTICE ini_check_section: section/key not found: m00-s02-r01-i00->id
Fri 24 06:12:52 NOTICE ini_check_key: key found: m00-s02-r01-i00->string
Fri 24 06:12:52 NOTICE ini_read_string: value found: m00-s02-r01-i00->string = "Usage: "
Fri 24 06:12:52 NOTICE ini_check_section: section found: m00-s02-r01-i01
Fri 24 06:12:52 NOTICE ini_read_word: value found: m00-s02-r01-i01->length = 0
Fri 24 06:12:52 NOTICE ini_read_byte: value found: m00-s02-r01-i01->options = 0
Fri 24 06:12:52 NOTICE ini_check_key: key found: m00-s02-r01-i01->id
Fri 24 06:12:52 NOTICE ini_read_dword: value found: m00-s02-r01-i01->id = 3411057955
Fri 24 06:12:52 NOTICE ini_check_section: section not found: m00-s02-r01-i02
Fri 24 06:12:52 NOTICE ini_read_byte: value found: m00-s02-r02->options = 0
Fri 24 06:12:52 NOTICE ini_read_dword: value found: m00-s02-r02->scroll_speed = 250
Fri 24 06:12:52 NOTICE ini_check_section: section found: m00-s02-r02-i00
Fri 24 06:12:52 NOTICE ini_read_word: value found: m00-s02-r02-i00->length = 15
Fri 24 06:12:52 NOTICE ini_read_byte: value found: m00-s02-r02-i00->options = 0
Fri 24 06:12:52 NOTICE ini_check_section: section/key not found: m00-s02-r02-i00->id
Fri 24 06:12:52 NOTICE ini_check_key: key found: m00-s02-r02-i00->string
Fri 24 06:12:52 NOTICE ini_read_string: value found: m00-s02-r02-i00->string = " "
Fri 24 06:12:52 NOTICE ini_check_section: section found: m00-s02-r02-i01
Fri 24 06:12:52 NOTICE ini_read_word: value found: m00-s02-r02-i01->length = 0
Fri 24 06:12:52 NOTICE ini_read_byte: value found: m00-s02-r02-i01->options = 0
Fri 24 06:12:52 NOTICE ini_check_key: key found: m00-s02-r02-i01->id
Fri 24 06:12:52 NOTICE ini_read_dword: value found: m00-s02-r02-i01->id = 1609017169
Fri 24 06:12:52 NOTICE ini_check_section: section found: m00-s02-r02-i02
Fri 24 06:12:52 NOTICE ini_read_word: value found: m00-s02-r02-i02->length = 0
Fri 24 06:12:52 NOTICE ini_read_byte: value found: m00-s02-r02-i02->options = 0
Fri 24 06:12:52 NOTICE ini_check_section: section/key not found: m00-s02-r02-i02->id
Fri 24 06:12:52 NOTICE ini_check_key: key found: m00-s02-r02-i02->string
Fri 24 06:12:52 NOTICE ini_read_string: value found: m00-s02-r02-i02->string = "%"
Fri 24 06:12:52 NOTICE ini_check_section: section not found: m00-s02-r02-i03
Fri 24 06:12:52 NOTICE ini_read_byte: value found: m00-s02-r03->options = 0
Fri 24 06:12:52 NOTICE ini_read_dword: value found: m00-s02-r03->scroll_speed = 250
Fri 24 06:12:52 NOTICE ini_check_section: section found: m00-s02-r03-i00
Fri 24 06:12:52 NOTICE ini_read_word: value found: m00-s02-r03-i00->length = 0
Fri 24 06:12:52 NOTICE ini_read_byte: value found: m00-s02-r03-i00->options = 0
Fri 24 06:12:52 NOTICE ini_check_section: section/key not found: m00-s02-r03-i00->id
Fri 24 06:12:52 NOTICE ini_check_key: key found: m00-s02-r03-i00->string
Fri 24 06:12:52 NOTICE ini_read_string: value found: m00-s02-r03-i00->string = " "
Fri 24 06:12:52 NOTICE ini_check_section: section not found: m00-s02-r03-i01
Fri 24 06:12:52 NOTICE ini_check_section: section found: m00-s03
Fri 24 06:12:52 NOTICE ini_read_string: value found: m00-s03->screen_name = "CPU+HDD+MEM+SWP Histogram"
Fri 24 06:12:52 NOTICE ini_read_byte: value found: m00-s03->options = 0
Fri 24 06:12:52 NOTICE ini_read_word: value found: m00-s03->alt_delay = 5000
Fri 24 06:12:52 NOTICE ini_check_section: section not found: m00-s03-event00
Fri 24 06:12:52 NOTICE ini_read_byte: value found: m00-s03-r00->options = 0
Fri 24 06:12:52 NOTICE ini_read_dword: value found: m00-s03-r00->scroll_speed = 250
Fri 24 06:12:52 NOTICE ini_check_section: section found: m00-s03-r00-i00
Fri 24 06:12:52 NOTICE ini_read_word: value found: m00-s03-r00-i00->length = 5
Fri 24 06:12:52 NOTICE ini_read_byte: value found: m00-s03-r00-i00->options = 0
Fri 24 06:12:52 NOTICE ini_check_section: section/key not found: m00-s03-r00-i00->id
Fri 24 06:12:52 NOTICE ini_check_key: key found: m00-s03-r00-i00->string
Fri 24 06:12:52 NOTICE ini_read_string: value found: m00-s03-r00-i00->string = " CPU "
Fri 24 06:12:52 NOTICE ini_check_section: section found: m00-s03-r00-i01
Fri 24 06:12:52 NOTICE ini_read_word: value found: m00-s03-r00-i01->length = 0
Fri 24 06:12:52 NOTICE ini_read_byte: value found: m00-s03-r00-i01->options = 0
Fri 24 06:12:52 NOTICE ini_check_key: key found: m00-s03-r00-i01->id
Fri 24 06:12:52 NOTICE ini_read_dword: value found: m00-s03-r00-i01->id = 319156400
Fri 24 06:12:52 NOTICE ini_check_section: section not found: m00-s03-r00-i02
Fri 24 06:12:52 NOTICE ini_read_byte: value found: m00-s03-r01->options = 0
Fri 24 06:12:52 NOTICE ini_read_dword: value found: m00-s03-r01->scroll_speed = 250
Fri 24 06:12:52 NOTICE ini_check_section: section found: m00-s03-r01-i00
Fri 24 06:12:52 NOTICE ini_read_word: value found: m00-s03-r01-i00->length = 5
Fri 24 06:12:52 NOTICE ini_read_byte: value found: m00-s03-r01-i00->options = 0
Fri 24 06:12:52 NOTICE ini_check_section: section/key not found: m00-s03-r01-i00->id
Fri 24 06:12:52 NOTICE ini_check_key: key found: m00-s03-r01-i00->string
Fri 24 06:12:52 NOTICE ini_read_string: value found: m00-s03-r01-i00->string = " HDD "
Fri 24 06:12:52 NOTICE ini_check_section: section found: m00-s03-r01-i01
Fri 24 06:12:52 NOTICE ini_read_word: value found: m00-s03-r01-i01->length = 0
Fri 24 06:12:52 NOTICE ini_read_byte: value found: m00-s03-r01-i01->options = 0
Fri 24 06:12:52 NOTICE ini_check_key: key found: m00-s03-r01-i01->id
Fri 24 06:12:52 NOTICE ini_read_dword: value found: m00-s03-r01-i01->id = 1262718300
Fri 24 06:12:52 NOTICE ini_check_section: section not found: m00-s03-r01-i02
Fri 24 06:12:52 NOTICE ini_read_byte: value found: m00-s03-r02->options = 0
Fri 24 06:12:52 NOTICE ini_read_dword: value found: m00-s03-r02->scroll_speed = 250
Fri 24 06:12:52 NOTICE ini_check_section: section found: m00-s03-r02-i00
Fri 24 06:12:52 NOTICE ini_read_word: value found: m00-s03-r02-i00->length = 5
Fri 24 06:12:52 NOTICE ini_read_byte: value found: m00-s03-r02-i00->options = 0
Fri 24 06:12:52 NOTICE ini_check_section: section/key not found: m00-s03-r02-i00->id
Fri 24 06:12:52 NOTICE ini_check_key: key found: m00-s03-r02-i00->string
Fri 24 06:12:52 NOTICE ini_read_string: value found: m00-s03-r02-i00->string = " MEM "
Fri 24 06:12:52 NOTICE ini_check_section: section found: m00-s03-r02-i01
Fri 24 06:12:52 NOTICE ini_read_word: value found: m00-s03-r02-i01->length = 0
Fri 24 06:12:52 NOTICE ini_read_byte: value found: m00-s03-r02-i01->options = 0
Fri 24 06:12:52 NOTICE ini_check_key: key found: m00-s03-r02-i01->id
Fri 24 06:12:52 NOTICE ini_read_dword: value found: m00-s03-r02-i01->id = 1300322674
Fri 24 06:12:52 NOTICE ini_check_section: section not found: m00-s03-r02-i02
Fri 24 06:12:52 NOTICE ini_read_byte: value found: m00-s03-r03->options = 0
Fri 24 06:12:52 NOTICE ini_read_dword: value found: m00-s03-r03->scroll_speed = 250
Fri 24 06:12:52 NOTICE ini_check_section: section found: m00-s03-r03-i00
Fri 24 06:12:52 NOTICE ini_read_word: value found: m00-s03-r03-i00->length = 5
Fri 24 06:12:52 NOTICE ini_read_byte: value found: m00-s03-r03-i00->options = 0
Fri 24 06:12:52 NOTICE ini_check_section: section/key not found: m00-s03-r03-i00->id
Fri 24 06:12:52 NOTICE ini_check_key: key found: m00-s03-r03-i00->string
Fri 24 06:12:52 NOTICE ini_read_string: value found: m00-s03-r03-i00->string = " SWP "
Fri 24 06:12:52 NOTICE ini_check_section: section found: m00-s03-r03-i01
Fri 24 06:12:52 NOTICE ini_read_word: value found: m00-s03-r03-i01->length = 0
Fri 24 06:12:52 NOTICE ini_read_byte: value found: m00-s03-r03-i01->options = 0
Fri 24 06:12:52 NOTICE ini_check_key: key found: m00-s03-r03-i01->id
Fri 24 06:12:52 NOTICE ini_read_dword: value found: m00-s03-r03-i01->id = 2091817875
Fri 24 06:12:52 NOTICE ini_check_section: section not found: m00-s03-r03-i02
Fri 24 06:12:52 NOTICE ini_check_section: section not found: m00-s04
Fri 24 06:12:52 NOTICE ini_check_section: section not found: m01
