laser92awd
My CFA-632 shows no signs of life when hooked up this way:
I have an MSI RS482M4 mainboard. It has a 10 pin serial header connector on the mainboard which I have assigned to COM2 in the BIOS (2F8,IRQ3).
I purchased a WR232Y08 cable which fits the mainboard header on one end, and the male DB9 connector on the back of my CFA-632.
The pin assignments on my mainboard header are:
1 DCD
2 SIN
3 SOUT
4 DTR
5 GND
6 DSR
7 RTS
8 CTS
9 RI
10 no pin
I know my CFA-632 is working, because when I connect it to my other PC (which has an external serial port) it works fine.
My COM2 port shows up in XP's device manager and appears to be working properly.
I do not have a header > DB9 bracket adapter to try an external hookup (and I'm really hoping for a totally internal hookup).
I have the CFA-632 jumpered for 19200 baud (same as the other PC). But when I try to use the display, I get nothing. No backlight, no text.
I don't think they are communicating with each other.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I have a feeling a couple pins need to get flipped, but I don't know which ones or what method I should use to make that happen.
I'd sure appreciate any help!
1 DCD
2 SIN
3 SOUT
4 DTR
5 GND
6 DSR
7 RTS
8 CTS
9 RI
10 no pin
