Boot Screen Editor Problem
BURRHEAD
When I attempt to run the boot screen editor I get a messages that states
"Failed to load MSCOMM" mscom32.ocx mayb be out of date.
Can someone explain what this means and what I need to do??
Knight
MSComm.ocx is the control that allows the serial port to be used in Visual Basic and a couple other programming languages.
In order to fix this, you need to get a updated copy of the control.
Surf around Microsoft's webpage. I'm not exactly certain where you can obtain this control.
It's protected by copyright laws, so I can't just attach it for you; otherwise I would.
I don't know of where to get ahold of it exactly.
You might want to do a search on your computer and see if you have it already, if you do it might be out of date version, OR not properly registered. Do a search and get back to me.
Search for:
mscomm32.ocx
and see if you find it.
