Crystalmancer
This screen is specific the CF635 with the SCAB module. It uses fan 1 header. If you are using all the fan headers on the SCAB, you could connect the Power Adaptor to a motherboard fan header and read that.
This shows the fans RPMs.
Animation: Nothing really special. I just made it look like a dual 120mm radiator, instead of just a fan. But it looks pretty cool.
Detail of animation:
Author: Crystalmancer
Screen zip file: Black Ice Stealth 240.zip
Install Instructions:
Copy the gif file to C:\gifs. Or simply use the GIF in your own screen.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Copy the screen out of the zip into the: C:\Program Files\CrystalControl2\cc2-config\screens directory, add them to your module.
You many need to adjust your calc.ini to fine tune it to your fans tach pulse.
Included are 20x4 screen files.
Development thread: N/A.
Hopefully, it works as well for you as it does for me.
Hope you enjoy!
Crystalmancer
![](http://www.crystalfontz.com/backlight/forum/userscreen/78/CM/black_ice_stealth_radiator_240.jpg)
![](http://www.crystalfontz.com/backlight/forum/userscreen/78/CM/6xblack_ice_radiator_240.gif)
Hope you enjoy!
Crystalmancer
