Backlight on a CFAH200AA-GGB-JP
Beers
Hello
I wired my first LCD up (the blue background with white text ones) and I must have put the 12 volt wire on the + terminal instead of 5 volt wire. At that point i had already soldered a lot thinking it was a short, but then came back and realized that i probably shorted it out.
I have my new LCD screen currently all wired up and working. It interfaces with the host computer and everything.
Then i get to backlighting.
I came to the site and looked around. All the posts are about the formula to find the right resistor. I calculated that i needed a 3.57 Ohm resistor.
My question is, Where can i find a resistor that low? or could I just hook the backlight directly up to the power? (~5.2 volts)
I used:
(5.2-4.6) / .280 = 3.571... My power supply outputs at about 5.2v now. It may change once its in with other circuits and devices.
Any suggestions? I checked radio shack and they dont have that low of a resistor.
Thx
PS- sorry if i rambled, its 3am :)
Beers
I got another question now.
I got two of the 10 Ohm resistors and put them in parallel and got around 5 Ohms, thats good.
I hooked it all up, backlight works. Good level of brightness is given off.
After having it on a while, i noticed the resistors got a lil warm. Is this normal??
Thanks again!
Yes, they will be warm. Here is the equation for the power (heat) dissapated in a resistor:
Pres = Vres * Ires
Pres = (5.2-4.2) * 0.210 = 210 mW
or about 1/5 of a watt of electrical energy will be converted to heat in the resistor.
Character LCD Modules
Beers
Yeah, i calculated that too, but I wanted to be sure that the resistors being warm wasnt a big issue.
Everything is working great, its in its little box, and now im writing code to interface with it.
Next time i may go with the serial LCD because they look to be better, but im going to wait till you have 4x20 with keypads + the color variation like the CFAH's.
Thanks again,
Adam
