The Crystalfontz CFA-633 has always had the ability to control the power supply on an "ATX" style PC motherboard + power supply combination. The WRPWRY14
now makes it easier than ever::
- Connect the WRPWRY14's "POWER" wire to the motherboard's power control pin.
- Connect the WRPWRY14's "RESET" wire to the motherboard's reset pin.
- Plug the WRPWRY14's "WOL" connector on the WRPWRY14 into the motherboard's "WOL" (Wake On Lan) connector.
- Plug the 7-pin connector of the WRPWRY14 onto the 633's mating header (we will pre-install the header to the 633 if you order the 633 and the WRPWRY14 at the same time).
- Configure the 633 to enable the ATX power control functions.
