Feels great to contribute to your massive to-do list!
The autoadjust feature works good. All previous visible histogram bars changes in proportion to the highest bar when a higher bar is displayed. The only downside is that if you, as in my case, are displaying a histogram over the bps currently beeing received by the NIC you will have at least one bar in full hight all the time (even if you are receiving 1 bps or 10 Mbps). This could give you a false impression that your NIC is havily used.
I've encountered two problems. I think it is like this, but I have to get back to confirm when I get home and can test it. If I set graph_min=0 and graph_max=-1 (min is 0bps and max is auto) then the histogram is not working at all and if I have min and max = -1 I get a constant histogram of half bar hight for the two rows displaying incoming "E in:" and "I in:" when there is no activity on the NICs.
EDIT: If I set graph_min=0 and graph_max=-1 I get a constant histogram of full hight.
multiplier=0.0009765625 is for converting bytes/sec to Mbytes/sec.
E and I on the screen stands for External (to Internet) NIC and Internal (to my intranet) NIC. Here's the screen definition file:
[pre]
rows=4
cols=20
[from00]
from="cc2_perfmon.ini"
sec="perf#"
opt01="id=@01"
opt02="full_name=\Network Interface(Intel[R] PRO_1000 CT Network Connection - Packet Scheduler Miniport)\Bytes Received/sec"
opt03="precision=0"
opt04="multiplier=0.0009765625"
[from01]
sec="perf#"
opt01="id=@02"
opt02="full_name=\Network Interface(Intel[R] PRO_1000 CT Network Connection - Packet Scheduler Miniport)\Bytes Sent/sec"
opt03="precision=0"
[from02]
sec="perf#"
opt01="id=@03"
opt02="full_name=\Network Interface(D-Link DFE-530TX PCI Fast Ethernet Adapter [rev.A] - Packet Scheduler Miniport)\Bytes Received/sec"
opt03="precision=0"
[from03]
sec="perf#"
opt01="id=@04"
opt02="full_name=\Network Interface(D-Link DFE-530TX PCI Fast Ethernet Adapter [rev.A] - Packet Scheduler Miniport)\Bytes Sent/sec"
opt03="precision=0"
[from04]
from="cc2_histogram.ini"
sec="graph#"
opt01="id_data=@01"
opt02="width=10"
opt03="height=1"
opt04="id3=@"
opt05="id2=@"
opt06="id1=@"
opt07="id0=@06"
opt08="scroll_speed=500"
opt09="graph_min=-1"
opt10="graph_max=-1"
opt11=id_gmin=@"
opt12="id_gmax=@"
[from05]
sec="graph#"
opt01="id_data=@02"
opt02="width=10"
opt03="height=1"
opt04="id3=@"
opt05="id2=@"
opt06="id1=@"
opt07="id0=@07"
opt11=id_gmin=@"
opt12="id_gmax=@"
[from06]
sec="graph#"
opt01="id_data=@03"
opt02="width=10"
opt03="height=1"
opt04="id3=@"
opt05="id2=@"
opt06="id1=@"
opt07="id0=@08"
opt11=id_gmin=@"
opt12="id_gmax=@"
[from07]
sec="graph#"
opt01="id_data=@04"
opt02="width=10"
opt03="height=1"
opt04="id3=@"
opt05="id2=@"
opt06="id1=@"
opt07="id0=@09"
opt11=id_gmin=@"
opt12="id_gmax=@"
[screen]
screen_name="Net Send/Receive Usage Histogram"
options=0
alt_delay=5000
[r00]
options=0
[r00-i00]
length=5
string="E In:"
[r00-i01]
length=5
options=0
id=@01
[r00-i02]
id=@06
[r01]
options=0
[r01-i00]
length=5
string="EOut:"
[r01-i01]
length=5
options=0
id=@02
[r01-i01]
id=@07
[r02]
options=0
[r02-i00]
length=5
string="I In:"
[r02-i01]
length=5
options=0
id=@03
[r02-i02]
id=@08
[r03]
options=0
[r03-i00]
length=5
string="I Out:"
[r03-i01]
length=5
options=0
id=@04
[r03-i01]
id=@09
/Daniel
