Mike Kramer
I just got my external USB 634XE and nothing happens when I plug it in. I'm using WinXP SP1 on a P4/i850EMV2. I've also tried plugging it into a Shuttle XPC/Nforce2, but the New Hardware Wizard does not pop up on either machine. Going through the Add Hardware Wizard manually also does not detect anything. The only possible compatibility problem I can think of is that both machines I've tried it on have USB 2.0 ports and the 634XE is probably USB 1.1, but that shouldn't be a problem, should it?
There is no wiring involved that I could be messing up, so does anyone have troubleshooting suggestions for how to get this thing detected? If windows doesn't ask for the driver the first time I plug it in, I'm sunk... Can I add the virtual COM port driver manually? Any suggestions will be appreciated. Thanks!
