634 Won't display a thing
wwillegems
I have CFA634TFBKS connected via a WR232Y08 cable to my internal com 2 on a via M-10000. When i open wintest or cc, I only get the blacklight and a blincking cursor. Yes the port is set to 19200 baud. What could be the problem. I saw a similar thread with no solution, so i launched a new one...
The WR232Y08 is made for a CFA-633. It is not intended to be used with a CFA-634.
It may work with a CFA-634, depending on the pin numbering scheme used by your motherboard manufacturer.
You would probably have to modify the cable to make it work.
Can you post the serial header pinout (with diagram) for your motherboard?
