Hi there!
A while ago I bought a 634 USB display.
While all went well for quite some time now this morning the display just went dead during a PC reboot. I mean, really dead. When plugged in it doesn't light up, it's not recognized by windows any more (neither the display, nor the USB-COM-Port), the status-led for the port on the hub doesn't light up, nothing.... (--> dead!)
Since the cable is ok and the display itself doesn't even get power I suspect it's just the USB-addon-board, and since returning the display for repair is not exactly an option due to the outragous shipping costs (spent 34$ on delivery last time including taxes and what not) and I'm pretty good with a soldering iron I took the liberty of completely disconnecting the addon-board from the display.
I gently soldered out the connections from J2 (with low heat), And the glue under the logo came off quite easily, too, so I'm pretty sure I didn't damage the main display board or any of it's components.
Now of course the question is, how can I get the display back up and running?
The easiest way for me would be to convert it to a serial display, I assume this is possible by adjusting the setting of JPA thru JPL.
Would you perhaps be so kind to tell me the correct setting for my display to re-enable the serial port?
If that's not an option (or turns out not to be doable) what about buying just a replacement USB-addon-board (I've got 632634v2.0 now)? Would it be possible to get such a board (as a replacement part), so I can solder it back on myself without having to send the entire display across the ocean AGAIN? What would the charge be?
My display is a 20x4 black positive display with white backlight, it says SKD204-634 V2.2 on the back.
Thanks for your help![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
