634 startup problem?
$onof$pam
when I run wintest the display contrast is set to max and I get these characters }}}}}}}}}} but after I run a test it will show the regular boot screen? It's just when it starts? I have the baud rates setup right and I know it used to work fine then I installed windows sp1 and now it messes up. Is thier a problem with the software and sp1 for winblows??
partofthething
I had this problem too and was able to fix it by running the boot screen setup utility. Just make a new boot screen or use the default and program it to memory. It fixed everything up for me.
