634 Installation Manual
rplaza
Hi, I purchased the CFA634-TFB-KS then I conected to my serial port and it worked perfect but without the backlight.
Then I found out that I need to put 5v to it in order to make it work.
But there's 2 5v inputs I don't want to tested each one because i'm afraid i can damage the display.
So I would like to read some instructions before installing it.
If someone have this information please share it with me.
RP.
You connect 5v to Pin 3 (VLED) for the backlight.
Usually we would attach the WR232Y02 cable to it if you ordered it at the same time.
rplaza
Backlight power conection
So just to be sure, I have to conect from my pc power supply a
Red (+5v) to (VLED) and the Black (ground) to ground directly without any resistance?
I read something on the forum that a 8 ohm resistance was used in between this cable.
