Here's the background info:
LCD Information
634 Lcd
RS232 for communications
baud @9600
dip switches set to 9600
Embedded System Info
Using Oopic for embedded circuit
Serial communications w RS232 no flow control
baud set @ 9600
Hyperterminal
baud @9600
No flow control
With the above in mind:
I am using the same cable for all of the following:
Scenerio 1 - PC Running Hyperterminal connected to LCD
Boot Screen comes up/off in 5 seconds
Typed characters appear as typed in hyperterminal
Everything works great
Scenerio 2 - PC Running Hyperterminal connected to Oopic
Oopic sends menu information to Hyperterminal
Hyperterminal recieves and displays correctly
Scenerio 3 - LCD connected to Oopic
Oopic sends menu information to LCD
No change in lcd
I can see the cursor so it isn't the contrast
Scenerio 1 verifies that the lcd receives and displays info sent from hyperterminal
Scenerio 2 verifies that the Oopic sends info and displays in Hyper Terminal
Hyper Terminal to LCD = Good
Oopic to Hyper Terminal= Good
Oopic to LCD = Bad(and Frustrated)
Any ideas on what else to try????
Note that the only change between scenerios is moving the serial cable from pc to Oopic, used same cable
Verified that all units work
Can't get Oopic to talk to LCD
Any help will be greatly appriciated
LCD Information
634 Lcd
baud @9600
baud set @ 9600
Hyperterminal
baud @9600
No flow control
No change in lcd
