I have installed 633 services, and CrystalControl. I also installed the USB drivers (since it is a USB connected screen). CrystalControl works fine, if i select 633-usb connected. Win Test also works fine and sees my 2 temperature sensors and the 2 fans i have connected for now. But 633 Services would not start. I set all the setting, select the ports, speeds, etc... It will set the right Power-On-Settings into to the screen. So when i just plug in my screen, without any software running the fans rotate at the right RPMs and 2 lines of text are displayed.
But the other options would not work. I looked in event log, the one kept by windows and the text file 633.log
both display the following
"(8/4/2003 6:05:04 PM) ERROR -> Unable to open or setup COM port. Check configurations. Terminating."
But i can communicate throught that port fine using WinTest and CrystalControl.
Please help.... What should i do???
