jockmacmad
I think my 633 is dying.
It started when the last two character positions only displayed solid blocks no matter what I sent to it.
Using CrystalControl it seems to not display any test but just flicker at high speed. However, if I tilit it to certain severe angles (about 70 degrees+) I can read the text.
If I close CyrstalControl and use WinTest the LCD does not light up at all. The ping & clear LCD commands work.
Setting the LCD line text fails with an error -
Command
C=7( 7 = LCD Line 1),L=7,D="Welcome",CRC=0x264C
Result
C=199(Error: Set LCD 1),L=0,D="",CRC=0x4188E5
A reboot results in the following command/response pair.
C=5( 5 = Reboot),L=0,D="",CRC=0x71FF
C=197(Error: Reboot),L=0,D="",CRC=0x41BB55
Can you shed any light on this.
Cheers
Don
Command
Result
Cheers
Don
