633 linux always...
Fabrizio
New machine, new LCD.
When I run the test code from the site, I get :
- Serial_Init : success
- 2 "Timed out waiting for a response"
- "Updated display. Now waiting for packets."
- Nothing displayed on the LCD (remains default)
- Nothing when I press any key
What should I test ? Or do ?
Fabrizio
CF Web
633 USB, I assume? Which distro?
Provide as much information as possible and I'll do my best to help.
Fabrizio
Oops sorry for the lack of information
633 on serial port
The distro is a slackware 10.2.
Kernel 2.6.13
The serial port is at 115200 baud.
But I also tried at 19200 changing it by :
setserial /dev/ttyS2 baud_base 19200
I can't any other relevant information.
Just ask if you think of something I forgot.
Fabrizio
Fabrizio
SOLVED
I am sorry. It had nothing to do with the 633.
Just in case someone run into the same problem one day :
There is apparently a problem in the serial driver that goes in the linux kernel, before version 2.6.14.6.
So, just update your kernel to that version or above and everything should be ok.
