632- adjusting column/row position
Merlin
i'm using a 632 interfaced to an Atmel micro. my question is this, i'm using the UART to send the lcd data, which works fine. but i want to adjust where certain text shows up, i was trying it like this.
printf("data");
putchar(17); //tells the lcd to adjust
putchar(0); //column 0
putchar(1); //row 1
printf("more data");
i was thinking this would show up as
data
more data
on the lcd. it isn't working though, any suggestions?
Hmmm . . . that looks like it should work.
Try:
printf("data");
putchar(1); //column 1
putchar(1); //row 1
That should do:
data
 more data
Some libraries go out of their way to have trouble sending a 0, maybe that is what is going on. I would not expect something called "putchar()" to have troubles like that though.
Merlin
yep that worked. i took it another step and put it in the format
printf("data");
putchar(17);
putchar(0x00);
putchar(1);
using the hex value for the column worked, i'm not for sure why though. so now i've got
data
more data
thanks
