631 Purchasing Options and Question
Voltaic
Well.. I think the 631 is what I'm after. Like I asked in the 633 "USB" thread though, I don't like the metal casing used to keep the LCD in the floppy driveslot.
So i guess first... Is it possible to buy the 631 without that metal frame?
Next.. What's the difference between the 631 USB LCD 20x2 +Keypad (CFA631-TMF-KU1) and 631 USB LCD 20x2 +Keypad (CFA631-TMF-KU2)?
As far as I can see, it's just the cable you're using to connect it with, right? (WRUSBY03 or WRUSBY11)
Thanks in advance!
Yes, the only difference is the cables supplied.
There is no way to seperate the CFA-631 from its frame, the whole unit is integral. It may be possible to remove the mounting rails close to the PCB . . . that would involve cutting metal very close to the electronice though, which would have to be done carefully.
Voltaic
Well.. I found the other thread with the "Void your Warranty" link, and I think that's what I possibly could end up doing. I'd have to think about that one though. Thanks for all the help guys! :)
