I've recently redone my 631 into an existing CD drive bay device that I was using for the Aerogate II. This uses the original case Hardcano 9 frame to house the display in a 5.25" bay, with a solid walnut insert, cut to fit, and formed to the frame's contours.
This is installed into the same Tt case I have been using, however, the original aluminum front inserts have also been replaced with solid walnut wood inserts, complete with dual front intake fan openings...
Belgarius
Belgarius
