2x8 character lcds
duke_stix
hey all
new to lcds and new to crystalfontz
im having a few issues with my LCD at the moment, its a 1x16 unit however, when setup using a 1x16 setting, only the first 8 blocks are used, this has led me to believe that perhaps this lcd is a 2x8 lcd with the two rows stuck next to each other.
is there anyway i can get crystalfontz to work with this?
thanx
All 1x16 LCDs that I'm aware of are laid out as a 2x8, with the lines concatenated. This layout allows the use of the single controller chip instead of using a controller chip plus a driver chip.
On page 8 of the data sheet, you can see the CGRAM address map, which shows the addresses in the right half of the display starting at 0x40.
duke_stix
hey
dont mean to be ignorant, but ive got no idea what your talking about.
how can i configure crystalfontz or any other lcd program such as lcdsmartie to output correctly to the lcd?
thank you.
The higher level software like LCDSmartie or CC1 should be aware of the 1x16 layout.
Most people use 2x16 LCDs, so maybe some of those have not been tested with a 1x16.
