20 x 4 nVidia/Everest CPU Stats Screen
20 x 4 nVidia/Everest GPU Stats Screen
CFA-635:
Detail of animation:
Author: Crystalmancer
Screen zip file: Crystalmancer_NVidia_Clocks_Temps_ANI.zip
Install Instructions:
Copy the gif file to C:\gifs.
Copy the screen out of the zip into the: C:\Program Files\CrystalControl2\cc2-config\screens directory, add them to your module.
You will need to have Everest installed and running. Get it here: http://www.lavalys.com/. You might have to have the registered version to be able to output Everest data to CC2. In order to set up Everest to do this, do the following:
File => Preferances.=> External Applications. Check the Box: "Enable writing sensor values to WMI". For convenience, I use the "Select All" option so that the values written to the WMI remain constant. Click on the OK button and you are ready to go.
Also, since different systems will most likely have different output data, you will probably have to change the Everest WMI values to match your system.
Development thread: N/A.
CFA-635:
