phishman3579
I have the Cfontz 634 LCD with the serial to USB connector. I am running Slackware 9.1 with Kernel 2.4.22. I am trying to get them to work together. I changed mt minicom set-up for ttyUSB0, 19200 baud, and no flow control, saved that set-up as minirc.dfl. I then can output test to the LCD screen.
Now, I am trying to work with LCDproc (0.5 CVS). I copied minirc.dfl to minirc.usb0 and then setup /etc/LCDd.conf. Here is the the set-up:
[server]
Driver=CFontz
[CFontz]
# CrystalFontz driver
# Use this driver for CF632 and CF634.
# Select the output device to use [/dev/lcd]
Device=/dev/ttyUSB0
# Select the LCD type (size) [20x4]
Size=20x4
# Set the initial contrast [140]
Contrast=140
# Set the initial brightness [255]
Brightness=255
# Set the initial off-brightness [0]
# This value is used when the display is normally
# switched off in case LCDd is inactive
OffBrightness=0
# Set the communication speed [9600]
# possible values: 1200, 2400, 9600
Speed=19200
# Set the firmware version (New means >= 2.0) [no]
NewFirmware=yes
# Reinitialize the LCD's BIOS [no]
# normally you shouldn't need this
Reboot=no
# Using CFont 632/634 with a USB option [no]
USB=yes
When I start LCDd and the lcdproc, all I get is a blank screen without the blinking cursor. When I change the driver to curses, I get the normal output onto my computer CRT (not lcd).
Anyone have any suggestions?
[server]
Driver=CFontz
[CFontz]
Device=/dev/ttyUSB0
Size=20x4
Contrast=140
Brightness=255
OffBrightness=0
Speed=19200
NewFirmware=yes
Reboot=no
USB=yes
