100% cpu Usage
pyrotek
Running a generic HD44780 and CC.
I have notied that CC is usign upwards from 35 to 100% of cpu time, a lot of them time , some times it will be low under 5% etc thats normal but its been up aroud the 55 to 100% a lot now.
Can any one tell me what i have done here?
thanks
pyrotek
pyrotek
Still gettign 100% abusage
It comes in waves
useing the pr3 now and same thing?
whats up with this?
or me? lol
thanks
pyrotek
Try slowing all the data update times in the Settings dialog.
If that fixes it, try turning them up one by one until you find out whats causing it.
pyrotek
This si a screen pic of befour i trued the settings down like you asked
next post will be one after i did
pyrotek
heres the pic after i turned everthign down
I still get the up and down cpu abusage thing?
is that normal?
Or is something wrong here?
thanks
pyrotek
pyrotek
As long as CC is on its permanly like that looks like its on a loop. It goes back to normaly only when CC is off
I have tryed the "Slow HD44780" option on and off it makes no diffrence to the cpu abusage.
anything else you need to know?
thanks
pyrotek
scsiguy
Pyrotek.....
I, too, am experiencing the same problem you have. Tried
to get some help here but got nowhere.
What I found was that with CC running, usage was anywhere
between 5 - 40 %. If I opened IE, usage went down to 0 - 7%.
Close IE and the usage then jumped to 80 - 100 % . Only way
to get the usage back down was to reboot the system and not
have IE open.
Suspect its a memory leak or some bug in CC .
pyrotek
scsiguy
plased to see i am not the only one
But IE has no effect on it as well it still dose the same thing as
the above picture weather IE is open or closed as long as CC is running its doing that.
I hope i can get some help or CC will be getting uninstaleld. Its usless the way it is now i rather not hafto since its nice softwhere
pyrotek
Next thing to try:
Remove all modules setup in CC.
Add a "Simulated LCD" and add some screens to that.
See if you still have the problem.
pyrotek
Ok
I added a sim LCD same specs as mine 16x2
added my saved screens to it
same settings everthing just a sim LCD
Though its more spikey now then box looking. <--- edit ;)
Same thing With CPU abusage.
any other thoughts?
pyrotek
pyrotek
ok
don't play games so i never use the game stats lol
Turned of e-mail and removed my e-mail screen seemed to have fixed the problem.
So whats up with that or can't i use e-mail right now?
thanks
pyrotek
Ah good.
I know whats causing the problem and ill see what i can do about it.
I dont know if ill be able to fix it though :(
pyrotek
No probs at last you know what it is.
if you need me to run CC in debug or something else
just give me a yell i can run it wile i'am at work it can chew cpu i don't care
thanks
pyrotek
As i said in another thread:
A quick update on this.
The email checking code does use 100% CPU time (nothing i can do about this), but the thread its running in is set at idle priority.
This means that while it does use 100% CPU time, it will not interrupt or slow down other applications or games.
