Network In and Out histograms
On a CFA-631:
Author: daks001
Screen zip file: network_in_and_out_histograms.zip
Install Instructions:
You will have to edit the following lines to match your network adapter in your system:
opt02="full_name=\Network Interface(Intel[R] PRO_1000 CT Network Connection)\Bytes Received/sec"
opt02="full_name=\Network Interface(Intel[R] PRO_1000 CT Network Connection)\Bytes Sent/sec"
If you run perfmon.exe you'll get the correct information from perfdump.txt.
This screen is for a CFA631 LCD.
Development thread: Download/Upload speeds with bargraph?.
