Ref: "Serial Communication Using RS-232 by Christian Blum"
http://www.z80.info/1656.htm
RS-232 signals on a "real" serial port look like this. These are the signals you would get if you had a CFA-735 with a CFA-RS232-01 installed:
The TTY protocol uses two different line states called 'mark' and 'space'.
(For the sake of clearness I name the line states 'high' (voltage) for
positive and 'low' (voltage) for negative voltages). If no data is
transmitted, the line is in its quiescent 'low' ('mark') state or in the
'break' state ('high'). Data looks like
space +---+ +---+ +---+ high '0' +5v ~ +12v
mark ----------+ +-------+ +---+ +------- low '1' -5v ~ -12v
(1) --------(2)-------- (3)
(1) start bit (2) data bits (3) stop bit(s)
If you have the CFA-RS232-01 installed, use "N,8,1" (
No parity,
8 data bits,
1 stop bit). The connection is then made to a "real" serial port, like you would find on a PC.
The CFA-RS232-01 has a RS232 level translator chip on it, and these chips have traditionally inverted the signal sense (ref:
http://www.exar.com/connectivity/transceiver/rs232/sp3220e ) so the signals before this ship are inverted compared to after it.
If you do not have the CFA-RS232-01 installed, then you are accessing the UART's Rx and Tx lines directly and the data looks like:
mark ----------+ +-------+ +---+ +------- high '1' ~ 3.3v
space +---+ +---+ +---+ low '0' ~0v
It is still "N,8,1" but you need to feed the signals to your microcontroller's UART Rx and Tx pins, like you would find on an Arduino or similar.
