I was recently tasked with powering up our new 16X2 Character OLED Modules:
These modules are pretty nice. They are the same size as our CFAH1602C series 16x2 Character LCD modules, and thinner as a bonus. The OLED's contrast is fantastic, and they have a crisp look that is hard to beat.
Another nice thing is that they have 4 software-selectable character sets, so you won't be stuck wanting for the omega or mu symbol.
Since I had an Arduino Uno handy, I decided to port the SPI version of the AVR code for this OLED to the Arduino. Here are all the parts you will need:
You will need to order your CFAL1602C pre-confgured for SPI, or follow the instructions in the CFAL1602C datasheet to make the conversion:
Once that is done, use some of the jumper wires to connect to the pins used for SPI on the CFAL1602C :
Then connect the 5v power and ground pins to the Arduino:
And complete the connections of the OLED's SPI pins to the Arduino:
You then just need to connect the Arduino to your PC and open the sketch CFAL1602C_SPI_Arduino.ino. Upload and you will be rewarded with OLED goodness:
About the code
The SPI is done in software, since the WS0010 OLED controller requires a 10-bit SPI transfer. Here is an implementation of "proper Arduino" code for the 10-bit SPI:
This code transfers at a clock frequency of about ~57KHz, and it takes about ~180uS, to complete one 10-bit write, you won't die from old age waiting for it:
But the old assembly-coding EE in me wanted to see if it could go a little faster
. Starting with some optimized Arduino Software SPI examples, I was able to do a bit better:
That speeds up things by a factor of 47 times, bringing a transfer from 180uS to 3.8us. The equivalent clock frequency from 247KHz to 2.6MHz. Very nice:
Of course either routine will work . . . the "proper Arduino" should be more portable.
Have fun connecting an OLED to your Arduino, feel free post your pictures or questions.
- Crystalfontz CFAL1602C OLED in your preferred color
- Connection wires. I used some standard 0.1" headers I had around, and a pack of WRJMPY40 jumper wires
- An Arduino Uno R3
- SS: Slave Select
- MOSI: Master (Arduino) Out, Slave (OLED) In
- MISO: Master (Arduino) In, Slave (OLED) Out
- SCK: Spi ClocK
About the code
//Straight-forward software SPI 10-bit transfer code, perhaps
//easier to understand, possibly more portable. Certainly slower.
// The SS pin is low for ~180uS, the clock frequency is ~57KHz
// 47x slower than above
//Select the chip, starting a 10-bit SPI transfer
digitalWrite(SPI_SS_PIN, LOW);
//(bit 0) Set the data(1)/command(0) flag
if(DATA==destination)
digitalWrite(SPI_MOSI_PIN, HIGH);
else
digitalWrite(SPI_MOSI_PIN, LOW);
//Clock it in.
digitalWrite(SPI_SCK_PIN, LOW);
digitalWrite(SPI_SCK_PIN, HIGH);
//(bit 1) Clear the read(1)/write(0) flag to write, clock it in.
//Clock it in.
//(bits 2-9) Push each of the 8 data bits out.
for(uint8_t mask=0x80;mask;mask>>=1)
//Set the MOSI pin high or low depending on if our mask
//corresponds to a 1 or 0 in the data.
if(mask&data)
else
//Clock it in.
//Release the chip, ending the 10-bit SPI transfer
digitalWrite(SPI_SS_PIN, HIGH);
//Pretty fast software SPI 10-bit transfer code
//Several ideas taken from the fastest non-assembly implementation at:
//http://nerdralph.blogspot.com/2015/03/fastest-avr-software-spi-in-west.html
// The SS pin is low for ~3.8uS, the clock frequency is ~ 2.6MHz
// 47x faster than above
//Pre-calculate the value that will drive clk and data low in one cycle.
//(Note that this is not interrupt safe if an ISR is writing to the same port)
register uint8_t
force_clk_and_data_low;
//Select the chip
CLR_SS;
//operation.
force_clk_and_data_low = (SPIPORT & ~(MOSI_MASK | SCK_MASK) );
//Set clock and data low
SPIPORT = force_clk_and_data_low;
//Set the data(1)/command(0) flag
SPITOGGLE = MOSI_MASK;
//Use a toggle to bring the clock up
SPITOGGLE = SCK_MASK;
//MOSI is already 0, for read(1)/write(0) flag as write
//Now clock the 8 bits of data out
if(data & 0x80)
if(data & 0x40)
if(data & 0x20)
if(data & 0x10)
if(data & 0x08)
if(data & 0x04)
if(data & 0x02)
if(data & 0x01)
//Release the chip
SET_SS;
