Winamp 2.x support
Masternemesis
does anyone know where i can get a winamp 2.x plugin for my model 634 USB LCD display? I'm looking for one that will show the peaks and so on. Thank you
Americanfreak
This is from the vis_lcdriver.dll read me......
The plugin is fairly straightforward - once you've run the install
program or copied the vis_lcdriver.dll file into the Winamp plugins
directory, go to the Select Visualization and click on this plugin,
then you can select a vis from the pulldown menu:
Also you have to turn off the little visual window in winamp....
see att.
Admiral_Red
Help, I have copied the .dll into my plugion directory, but I still can not select it as a vis! What am I doing wrong?
James
