Temps via Bargraphs and Histograms, Speedfan
'Temps via Bargraphs and Histograms, Speedfan' is purely an edit of some screens devised by Daks, our erstwhile LCD graphics expert! I think you will agree, his screens really bring the 631 and 634 modules to life whilst portaying the information we require.
These new screen edits are to show the Speedfan version of CPU, PWM and HD0 as follows
Speed- All Temps- Histograms-2002 (631)
Speed- All Temps- Bargraphs-2002 (631)
Speed-All Temps-Bargraphs-2004 (634)
Speed-All Temps-Histograms-2004 (634)
They can be changed to show other drives, PSU`s etc... To do this you need to change the ID numbers.
If you need to change ID`s to suit your setup, then use my test screens to find the correct ID numbers and then paste them into the screens. In most cases no change will be necessary.
If you do need to change any ID`s then they all currently run from top down in the form of
CPU
PWM
HD0
This data is repeated in the same format and chronological order further down the list. So changing one ID means entering it twice in the correct place for each screen.
Steve
Speed- All Temps- Histograms-2002 (631) shows as follows
CPU:Temp(n) PWM:Temp(n) HD0:Temp(n)
Histogram Histogram Histogram
Where Temp(n) represents the actual temp reading from Speedfan and Histogram shows the required chart.
Steve
  • speed- all temps- histograms-2002.zip
Speed- All Temps- Bargraphs-2002 (631) shows as follows
Bargraph Bargraph Bargraph
Where Temp(n) represents the actual temp reading from Speedfan and Bargraphs shows the required chart.
Steve
  • speed- all temps- bargraphs-2002.zip
Speed-All Temps-Histograms-2004 (634) shows as follows
TEMPERATURES
Where TEMPERATURES is the title. Temp(n) represents the actual temp reading from Speedfan and Histogram shows the required chart.
Steve
  • speed-all temps-histograms-2004.zip
Speed-All Temps-Bargraphs-2004 (634) shows as follows
TEMPERATURES
Bargraphs Bargraphs Bargraphs
Where TEMPERATURES is the title. Temp(n) represents the actual temp reading from Speedfan and Bargraphs shows the required chart.
Steve
  • speed-all temps-bargraphs-2004.zip
